Obecny czas: Poniedziałek, 25 Maj 2026, 07:40
Napisz nowy temat Odpowiedz  [ 14 posty(ów) ]  Idź do strony 1, 2  Następna
 Temat postu: GREEK TOURNAMENT OPEN 13-03-2012
PostWysłany: Niedziela, 4 Marzec 2012, 08:44
Narodowość: GRE
VSK klub: HDT
http://greek-vsk.jimdo.com/greek-tournament/
NikGre HDTeam
 Temat postu: Re: GREEK TOURNAMENT OPEN 13-03-2012
PostWysłany: Niedziela, 4 Marzec 2012, 11:06
What about NOR & SI in English or Polish? :)
PostWysłany: Niedziela, 4 Marzec 2012, 16:23
na zapytanie o zasady turnieju otrzymałem taką odpowiedź:
its pen cancel.only 16.1-17.1
ja dziękuję :)
PostWysłany: Niedziela, 4 Marzec 2012, 23:30
Narodowość: GRE
VSK klub: HDT
Tournament Rules Time 22:00 GMT+2
1. Players will be divided into Group.Megistos player number 80 (ie 20 each group). There will be 2 qualifying races in each group. The final will be spent the first 16 boats. Example: If we have 2 Group will spend the first 8 in each group. If we have 3 group will spend the Top 5 and the best score of the group. In 4 group will spend the first 4 groups.
1. Fundamentals
Competitors in the sport of sailing are subject to a set of rules they must adhere to impose.
A fundamental principle of sportsmanship is that when competitors break a rule, you immediately get a penalty, which can be withdrawn.
2. Respect for opponents
during the games will not allow cursing or swear words to anyone. The conversation is used for issues related to race. Any dispute will go "from the management of the route.
3. Constant search
Competitors compete in compliance deveno recognized principles of sportsmanship and fair play. A boat may be penalized under this rule only if it is clear that these principles are violated.
4. Acceptance of Rules
By registering, each participant agrees to:
(a) submit to all rules contained in this communication and in the regulation of the tournament,
(b) accept the penalties imposed and other actions taken pursuant to the rules .
5. Decision to Race
The responsibility for the decision to join a competitor in a race or to continue racing is hers alone.
Who organizes the event and which hosta you provide a service and, almost always, is also involved.
would desirable to avoid excessive use of Chat with repeated requests for action on issues most diverse and often futile. This distracts and annoys those who struggle. Try to use your head and not the first instinct to write in chat game.
6. Rules
All matches will be organized by VSKA in accordance with the following rules and regulations - the ISAF regulations as applied to the latest version of the game. It is important to remember that the latest amendments to the Rules adopted by the ISAF VSK5. - All the racing fleet will take place in "regular" with automatic sanctions. - Ban penalties for cancellation subject to the exceptions referred to below. - The penalties for delay is not erasable. At the end of the race, who had been to forward the protest to get repairs.
7. No exceptions to the rule Cancel pen
- Penalty Rule 16.1 . If you feel that the server has erroneously granted, it is permissible to request cancellation. Just delete the application does not require
exceptions. The master who does not accept the cancellation request will be relegated to last place of the race. In cases where the master considers it just canceled a penalty, may, at the end of the match to send the complaint to the committee. If the sentence has been properly assigned, the master who has applied for cancellation will be relegated to the last part of the race. - Penalty Rule 17.1 .And "mandatory removal upstream and downstream, and goes cacellata stern. master who does not accept the cancellation request will be relegated to the bottom of the race. Commanders must request and obtain cancellation in a downwind leg will be relegated to last place in the race. To avoid disagreements and different interpretations, the notion of distance to the "stern" applies to all cases where it is absolutely clear that, starting from the simple buoy shot, you can reach the next beacon without the balloon drop.
8. Procedures for starting the race
in accordance with any continuing problems, the Regatta will be open 10 minutes before the scheduled start of play. Each contestant is required to know the pw entry will not be communicated in chat game to prevent the entry of potential competitors in the race came into the tournament. delay - Due to specific technical data transmission over the Internet, it is likely that a delayed appearance of ships or and / unexpected movements and non-homogeneous, this behavior, though obviously not voluntary because of difficulties with other participants, causing, in many cases, unfair penalties boats completely innocent. While recognizing the impossibility of eliminating the problem completely, some established procedures designed to reduce the problem to a minimum: Before departure : You made a "test delay", in which particepanti encouraged to report any delay. If so, the host evaluates the situation and, after restartato once and remains the problem persists, decide what to do. If the delay is associated with only one competitor will be asked to leave the race.In case of refusal should be expelled. In this case the state would save a copy of repetition to ensure against possible disputes. If the delay is associated with more competitors will move to change the game and eventually the lag persist at a later stage, a change of host. after actual departure of the race, if delays are reported for a competitor within the limits of technical and functional capabilities (do not forget that the host is struggling like you!), the governor will be asked to leave or, if necessary, expelled. If the delay of many competitors, is the host and any members of the Committee to determine whether to complete or cancel the race. General Recall : will be up to two general recall when the number of masters OCS is: FROM 08 TO 11 SKIPEPRS = 3 OCS 12 έως 14 = 4 SKIPEPRS OCS 15 17 = 5 έως OCS governors from 18 to 20 6 OCS SKIPEPRS = The start of the third match will be valid regardless of the number of masters OCS.Apomeinaria the host may restart the race, in case, disconnect or a reckless maneuver by a competitor to create the conditions for determining the departure distortion in the functioning of more than one competitor. This feature is only for cases of specific entities. disconnected or follower : They can only participate if at the time of connection or reconnection, the server will Nadeo their presence in the water. No reboot to return ritardari or disconnected. If a competitor displays "Found New Year word, she can decide whether to continue or abandon the match. Should it decide to continue, it is the responsibility to save the full replay of the match and send the e-mail within 30 minutes n @ iko.siganos yahoo.gr the race will be considered valid only if the repetition will not " seen any jump in front of his boat. In this case, either in the absence of the booster will be ranked last.
NikGre HDTeam
PostWysłany: Wtorek, 13 Marzec 2012, 11:16
Damy radę!
Będzie przynajmniej penparty.
PostWysłany: Wtorek, 13 Marzec 2012, 12:49
Kefas, Spajda, ja. Kto jest tam jeszcze?
dobra, widzę:
Jul italy
Moya Tvoya Poland
KOKOS GREECE
gladiatore alessio
Barbarossa Greece
Mumblee italy
orza italia
Wetstuff greece
Spajda poland
von Reuffen Poland
POL_Kefas Poland
DORKUS POLAND
Maxx69 Italy
_AeToS_ greece
GMOS-GRE HELLAS
VELOS greece
ULI-ORCSA-VSKFUN Germany
zolfvolos Greece
SOLARIS_GRE greece
apson_GRE Greece
spias greece
BIGWHITE greece
gras1269 HDT hellas
DPD-orcas-VSKFUN GERMANY
alcapad france
JOLARA Greece
1430GRE(IOAN) greece
L[GRE] Greece
sabbas greece
DAMGRE greece
NIKOLAS GRE greece
Ale jaka to jest godzina, 20 GMT + 2?
PostWysłany: Wtorek, 13 Marzec 2012, 13:18
Rafal, naszego czasu bedzie to 21:00
Wiec nie przespij ;)
U nas panuje GMT+1 (CET)
Jakbys byl w londynie to musialbys plynac o 20:00
PostWysłany: Wtorek, 13 Marzec 2012, 14:45
22 ...?
PostWysłany: Wtorek, 13 Marzec 2012, 16:24
22:00 GMT+2 = 21:00 GMT+1 = 20:00 GMT
Im dalej na wschód tym później.
My jesteśmy w CET = GMT+1
Ostatnio Kefas Ruscy przedobrzyli z GMT dlatego się spóźniliśmy 2h na regaty :P
PostWysłany: Wtorek, 13 Marzec 2012, 17:53
Hehe... wracając z pracy tramwajem coś mnie tknęło... objaw tego pojawił się na Ahoju.... :D ...teraz widzę to samo tutaj! :D
