| Polish Virtual Sailing Club http://pol-vsc.org/forums/ |
| Nordic Championship 2013 http://pol-vsc.org/forums/viewtopic.php?f=62&t=4462 |
Strona 1 z 5 |
| Autor: | XtraVert [ Poniedziałek, 7 Styczeń 2013, 09:00 ] |
| Temat postu: | Nordic Championship 2013 |
Rejestracja VSK Nordic once again invites you to the Nordic ACC Championship. To be crowned as Nordic Champion, you have to beat the strongest pool of competitors. The event has got a reputation that attracts the very best VSK sailors, so if you think you can sail, this is where to prove it... Details: Who: Owners of the full version of VSKAC32/VSK5/Vsk5Online, limited to a maximum total of 80 (*) What: Acc Fleet Race Where: Various VSK5 Seascapes When: January 15th, 17th, 22nd, 24th, 29th and 31st at 21:00 CET Registration deadline: Sunday January 13th |
| Autor: | XtraVert [ Wtorek, 15 Styczeń 2013, 10:24 ] |
| Temat postu: | Re: Nordic Championship 2013 |
Dzisiaj 21:00 Fleet A - Race Q1 and Q2 Boat Nat Merlin DEN YoKKo SWE Grozniy RUS Hun-Kon-Scian FRA KrisDen DEN Peppino SUI daitarn3 ITA roger__xiii POL Jul ITA Topcha RUS BatBoat DEN Delphisa FRA DPD-Orcas GER John Pap GRE J@y IRE Mange SWE Blue Lady GER ruppsack GER Beebob DEN Lumba SLO Fleet B - Race Q1 and Q2 Boat Nat North Star DEN Luna FRA jiel FRA BZH FRA El Rocco FRA fasttits USA Afonso POR Spirillen DEN Goffe SWE Nicnad DEN Lampo ITA Kong DEN Rakosi DEN G.mos GRE Onyx SUI 011 SUI Morten1211 DEN Made in Italy ITA A2 - Mover DEN Fix oder Nix GER Bricaur DEN Fleet C - Race Q1 and Q2 Boat Nat Lazy.se SWE euphoria NOR Tilo FRA Kefas POL svalebo DEN spittillo ITA Seb808 ESP Blue Sweden SWE Shpill RUS mloi1 ITA Egon POL kadofatdet DEN Morgan FRA ElMoro GER yz ISL Peter...G DEN Dmi3Y UKR Strateg RUS Haliz RUS damgre GRE Fleet D - Race Q1 and Q2 Boat Nat PKUlm GER Ryh00 POL carlos POR Starrus RUS Black Pete SWE Djonny66 RUS krulle DEN Etoile des Neiges FRA ponpon666 FRA Alameda FRA jendza POL Camster SCO Winslow SWE Seawind DEN Arioñe ITA Liburnia ITA Bent P DEN Stempel POL Dorkus POL WetStuff GRE Fleet E - Race Q1 and Q2 Boat Nat Tulle DEN Mogh Waï FRA Ivanhoe ITA nikgre GRE edotomsail ITA plitkin POL CZA_REK POL Chico POR Gadget DEN Mikolaj POL Gandos ITA nuuk GER DennisConner GER merendina ITA Artur POL Brun Sail NOR SoVA RUS FLYIN´ FIN FIN Orione ITA cocal ITA |
| Autor: | XtraVert [ Wtorek, 15 Styczeń 2013, 10:41 ] |
Kary: PENALTY SYSTEM 8.1 The penalties are as follows: · For penalties assigned by VSK: One-Turn Penalty (360 za kary Nadeo) · For breaches of rules where VSK did not assign any penalty: One-Turn Penalty (360 za złamanie przepisów) · For breaches of rules leading to any kind of penalty assigned by VSK to an innocent boat, of which cannot be cancelled: Two-Turns Penalty (2x360 jeżeli z powodu złamania przepisów zostanie przyznana niewinnej łodzi kara której nie można anulować) 8.2 Penalties assigned by VSK which a participant considers incorrect, do not have to be taken. Such penalties should be requested to be cancelled. Penalties that are requested to be cancelled must be cancelled (approved) by the other competitor. Even for pens the receiver of the request believes are correct. If a participant refuses to cancel a penalty after a request, she may be considered breaking rule 2. If an incorrect penalty is refused to be cancelled, the boat that got the penalty is entitled to redress. If a correct penalty is cancelled, actions should be taken as described in SI article A.3. See also SI article A2.1.2. (Niezasadne kary można anulować, skiper który nie potwierdzi anulowanie kary będzie rozpatrywany jak za złamanie przepisu 2. W przypadku nie potwierdzenia anulownaia nieprawidłowej kary można żądać redressu). 10 PROTESTS AND REQUESTS FOR REDRESS 10.1 For each fleet, the protest time limit is 60 minutes after the last boat has finished the last race of the day. (czas na składanie protestów do sytuacji w biegach z danego dnia - 60 minut po wpłynięciu na metę ostatniego zawodnika w ostatnim biegu danego dnia) 10.2 Protests shall be communicated to the protest committee as described in SI Appendix A3. (dokładny opis składania protestów w załączniku A3) 10.4 If the PC finds that the protested boat without doubt has not broken a rule, and the protestor should have known this, then the protestor will be penalized with 1 point, which will be added to her series score. (niezasadny protest będzie karany dodatkowym punktem do klasyfikacji) 10.5 There are no appeal options. (nie ma odwołań od decyzji) Protesty na wodzie tak jak u nas. W przypadku nieprawidłowej obsługi protestu na wodzie każdy uczestnik wyścigu może złożyć protest po wyścigu. |
| Autor: | plitkin [ Wtorek, 15 Styczeń 2013, 10:56 ] |
Ale jest ciekawy system z tego co zrozumialem (prosze o poprawienie mnie): anulowania nie musze wyjasniac, a jezeli druga strona uzna je za nieprawidlowe - powinna zlozyc protest. Czyli tak jak na prawdziwej wodzie:nie przyjmuje kolka i nikomu sie nie tlumacze do czasu az nie dostane formalnego protestu przy zielonym stoliku. |
| Autor: | XtraVert [ Wtorek, 15 Styczeń 2013, 11:19 ] |
plitkin napisał: Ale jest ciekawy system z tego co zrozumialem (prosze o poprawienie mnie): anulowania nie musze wyjasniac, a jezeli druga strona uzna je za nieprawidlowe - powinna zlozyc protest. Czyli tak jak na prawdziwej wodzie:nie przyjmuje kolka i nikomu sie nie tlumacze do czasu az nie dostane formalnego protestu przy zielonym stoliku. Tak... u nas też tak było planowane, ale włączyliśmy czynnik edukacyjny i uniemożliwienie przyjacielskich anulowań. Tutaj - oni dali możliwość protestowania przez inne osoby którą widzą sytuację. |
| Autor: | Maaniek [ Wtorek, 15 Styczeń 2013, 11:22 ] |
Proszę wszystkich uczestników o krótkie relacje po swoich wyścigach. Mamy zamówienie na relacje do Żagli, więc jakoś to chciałbym ogarnąć. Może ktoś podrzuci mi nicki faworytów innych nacji. Jeszcze się w tym nie rozeznaję. POWODZENIA |
| Autor: | plitkin [ Wtorek, 15 Styczeń 2013, 11:26 ] |
Wszystkie narody sa zgodne co do faworytow: Mikolaj, Ryhoo, Artur, Kefas, Egon, Jendza, Roger, Stempel, Dorkus i Czarek! Nie ma inych faworytow! |
| Autor: | XtraVert [ Wtorek, 15 Styczeń 2013, 11:40 ] |
To na przykład z mojej grupy - tych podkreślonych kojarzę i chyba cały czas pływają. Przy spięciu pośladków do objechania chyba wszyscy. Bez spinania - stawiam na połowę stawki podkreślonych. Z rozprężeniem jakie ostatnio mnie przed monitorem prześladuje - koniec stawki globalnej! Chociaż nie wiem na co stać takie osoby jak oznaczone na zielono Fleet C - Race Q1 and Q2 Boat Nat Lazy.se SWE euphoria NOR Tilo FRA Kefas POL svalebo DEN spittillo ITA Seb808 ESP Blue Sweden SWE Shpill RUS mloi1 ITA Egon POL kadofatdet DEN Morgan FRA ElMoro GER yz ISL Peter...G DEN Dmi3Y UKR Strateg RUS Haliz RUS damgre GRE |
| Autor: | Maaniek [ Wtorek, 15 Styczeń 2013, 12:37 ] |
Kefas dzięki. Może ktoś jeszcze się wysili do wieczora? |
| Autor: | mikolaj1532 [ Wtorek, 15 Styczeń 2013, 14:14 ] |
Faworyci zagraniczni: Lumba, Yokko, Jay, BZH, Spirllieren, euphoria, spittillo, DennisConner. |
| Strona 1 z 5 | Wszystkie czasy w strefie UTC + 1 godzina |
| Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
