Obecny czas: Wtorek, 29 Wrzesień 2026, 19:33
Napisz nowy temat Odpowiedz  [ 50 posty(ów) ]  Idź do strony 1, 2, 3, 4, 5  Następna
 Temat postu: Nordic Championship 2013
PostWysłany: Poniedziałek, 7 Styczeń 2013, 09:00
Rejestracja
VSK Nordic once again invites you to the Nordic ACC Championship. To be crowned as Nordic Champion, you have to beat the strongest pool of competitors. The event has got a reputation that attracts the very best VSK sailors, so if you think you can sail, this is where to prove it...
Details:
Who: Owners of the full version of VSKAC32/VSK5/Vsk5Online, limited to a maximum total of 80 (*)
What: Acc Fleet Race
Where: Various VSK5 Seascapes
When: January 15th, 17th, 22nd, 24th, 29th and 31st at 21:00 CET
Registration deadline: Sunday January 13th
 Temat postu: Re: Nordic Championship 2013
PostWysłany: Wtorek, 15 Styczeń 2013, 10:24
Dzisiaj 21:00
Fleet A - Race Q1 and Q2
Boat Nat
Merlin DEN
YoKKo SWE
Grozniy RUS
Hun-Kon-Scian FRA
KrisDen DEN
Peppino SUI
daitarn3 ITA
roger__xiii POL
Jul ITA
Topcha RUS
BatBoat DEN
Delphisa FRA
DPD-Orcas GER
John Pap GRE
J@y IRE
Mange SWE
Blue Lady GER
ruppsack GER
Beebob DEN
Lumba SLO
Fleet B - Race Q1 and Q2
Boat Nat
North Star DEN
Luna FRA
jiel FRA
BZH FRA
El Rocco FRA
fasttits USA
Afonso POR
Spirillen DEN
Goffe SWE
Nicnad DEN
Lampo ITA
Kong DEN
Rakosi DEN
G.mos GRE
Onyx SUI 011 SUI
Morten1211 DEN
Made in Italy ITA
A2 - Mover DEN
Fix oder Nix GER
Bricaur DEN
Fleet C - Race Q1 and Q2
Boat Nat
Lazy.se SWE
euphoria NOR
Tilo FRA
Kefas POL
svalebo DEN
spittillo ITA
Seb808 ESP
Blue Sweden SWE
Shpill RUS
mloi1 ITA
Egon POL
kadofatdet DEN
Morgan FRA
ElMoro GER
yz ISL
Peter...G DEN
Dmi3Y UKR
Strateg RUS
Haliz RUS
damgre GRE
Fleet D - Race Q1 and Q2
Boat Nat
PKUlm GER
Ryh00 POL
carlos POR
Starrus RUS
Black Pete SWE
Djonny66 RUS
krulle DEN
Etoile des Neiges FRA
ponpon666 FRA
Alameda FRA
jendza POL
Camster SCO
Winslow SWE
Seawind DEN
Arioñe ITA
Liburnia ITA
Bent P DEN
Stempel POL
Dorkus POL
WetStuff GRE
Fleet E - Race Q1 and Q2
Boat Nat
Tulle DEN
Mogh Waï FRA
Ivanhoe ITA
nikgre GRE
edotomsail ITA
plitkin POL
CZA_REK POL
Chico POR
Gadget DEN
Mikolaj POL
Gandos ITA
nuuk GER
DennisConner GER
merendina ITA
Artur POL
Brun Sail NOR
SoVA RUS
FLYIN´ FIN FIN
Orione ITA
cocal ITA
PostWysłany: Wtorek, 15 Styczeń 2013, 10:41
Kary:
PENALTY SYSTEM
8.1 The penalties are as follows:
· For penalties assigned by VSK: One-Turn Penalty (360 za kary Nadeo)
· For breaches of rules where VSK did not assign any penalty: One-Turn Penalty (360 za złamanie przepisów)
· For breaches of rules leading to any kind of penalty assigned by VSK to an innocent boat, of which cannot be cancelled: Two-Turns Penalty (2x360 jeżeli z powodu złamania przepisów zostanie przyznana niewinnej łodzi kara której nie można anulować)
8.2 Penalties assigned by VSK which a participant considers incorrect, do not have to be taken. Such penalties should be requested to be cancelled. Penalties that are requested to be cancelled must be cancelled (approved) by the other competitor. Even for pens the receiver of the request believes are correct. If a participant refuses to cancel a penalty after a request, she may be considered breaking rule 2. If an incorrect penalty is refused to be cancelled, the boat that got the penalty is entitled to redress. If a correct penalty is cancelled, actions should be taken as described in SI article A.3. See also SI article A2.1.2. (Niezasadne kary można anulować, skiper który nie potwierdzi anulowanie kary będzie rozpatrywany jak za złamanie przepisu 2. W przypadku nie potwierdzenia anulownaia nieprawidłowej kary można żądać redressu).
10 PROTESTS AND REQUESTS FOR REDRESS
10.1 For each fleet, the protest time limit is 60 minutes after the last boat has finished the last race of the day. (czas na składanie protestów do sytuacji w biegach z danego dnia - 60 minut po wpłynięciu na metę ostatniego zawodnika w ostatnim biegu danego dnia)
10.2 Protests shall be communicated to the protest committee as described in SI Appendix A3. (dokładny opis składania protestów w załączniku A3)
10.4 If the PC finds that the protested boat without doubt has not broken a rule, and the protestor should have known this, then the protestor will be penalized with 1 point, which will be added to her series score. (niezasadny protest będzie karany dodatkowym punktem do klasyfikacji)
10.5 There are no appeal options. (nie ma odwołań od decyzji)
Protesty na wodzie tak jak u nas.
W przypadku nieprawidłowej obsługi protestu na wodzie każdy uczestnik wyścigu może złożyć protest po wyścigu.
PostWysłany: Wtorek, 15 Styczeń 2013, 10:56
Ale jest ciekawy system z tego co zrozumialem (prosze o poprawienie mnie): anulowania nie musze wyjasniac, a jezeli druga strona uzna je za nieprawidlowe - powinna zlozyc protest. Czyli tak jak na prawdziwej wodzie:nie przyjmuje kolka i nikomu sie nie tlumacze do czasu az nie dostane formalnego protestu przy zielonym stoliku.
PostWysłany: Wtorek, 15 Styczeń 2013, 11:19
Tak... u nas też tak było planowane, ale włączyliśmy czynnik edukacyjny i uniemożliwienie przyjacielskich anulowań. :)
Tutaj - oni dali możliwość protestowania przez inne osoby którą widzą sytuację.
PostWysłany: Wtorek, 15 Styczeń 2013, 11:22
Proszę wszystkich uczestników o krótkie relacje po swoich wyścigach. Mamy zamówienie na relacje do Żagli, więc jakoś to chciałbym ogarnąć. Może ktoś podrzuci mi nicki faworytów innych nacji. Jeszcze się w tym nie rozeznaję.
POWODZENIA
PostWysłany: Wtorek, 15 Styczeń 2013, 11:26
Wszystkie narody sa zgodne co do faworytow: Mikolaj, Ryhoo, Artur, Kefas, Egon, Jendza, Roger, Stempel, Dorkus i Czarek! Nie ma inych faworytow!
PostWysłany: Wtorek, 15 Styczeń 2013, 11:40
To na przykład z mojej grupy - tych podkreślonych kojarzę i chyba cały czas pływają. :)
Przy spięciu pośladków do objechania chyba wszyscy.
Bez spinania - stawiam na połowę stawki podkreślonych.
Z rozprężeniem jakie ostatnio mnie przed monitorem prześladuje - koniec stawki globalnej! :D
Chociaż nie wiem na co stać takie osoby jak oznaczone na zielono :)
Boat Nat
Lazy.se SWE
euphoria NOR
Tilo FRA
Kefas POL
svalebo DEN
spittillo ITA
Seb808 ESP
Blue Sweden SWE
Shpill RUS
mloi1 ITA
Egon POL
kadofatdet DEN
Morgan FRA
ElMoro GER
yz ISL
Peter...G DEN
Dmi3Y UKR
Strateg RUS
Haliz RUS
damgre GRE
PostWysłany: Wtorek, 15 Styczeń 2013, 12:37
Kefas dzięki. Może ktoś jeszcze się wysili do wieczora?
PostWysłany: Wtorek, 15 Styczeń 2013, 14:14
Faworyci zagraniczni: Lumba, Yokko, Jay, BZH, Spirllieren, euphoria, spittillo, DennisConner.
